[ +/- ] [ Τώρα είναι Τρί Νοέμ 24, 2026 10:03 pm ]
 Renault Twingo Sport R2
Δημοσίευση Renault Twingo Sport R2
βλέποντας το εν λόγω αγωνιστικό να τρέχει στο irc είπα να δω περιτίνος πρόκειται ....
αρχικά με την τιμή
The Twingo Renault Sport R1 and R2 kits are available from March 15, 2010 with a priority for drivers entering the French Twingo R2 Trophy. The R1 kit is offered at 9,500€ (ex VAT), while the R2 kit goes on sale at 27,990€ (ex VAT) An additional R2 dirt kit is also featured in the catalogue at 7,500€ (ex VAT)
For each R1 or R2 kit purchased, Renault Sport Technologies will offer a special deal on the price of a new Twingo Renault Sport. Thanks to the involvement of the Renault Dealer Network this solution allows drivers to buy their Twingo Renault Sport complete, registered and, where necessary, financed at a preferential price.
θετικό ότι μπορείς να πάρεις το πολιτικό σε τίμη "αγωνιστική"
Chassis Engine
Type Steel monocoque with welded roll cage
Layout Front transversally-mounted
Type Renault K4M RS – 4 cylinder – 16 valve – 1,598cc
Bore x stroke 79.5 x 80.5mm
Ignition Built-in Magneti Marelli management system Production
Maximum power 160bhp (118kW) at 7,250rpm
Maximum torque 160Nm at 5,500rpm 160Nm (m.kg) at 4,400rpm
Max. engine speed 7,500rpm
Transmission
Type Front-wheel drive
Gearbox Sequential 5-speed gearbox + reverse
Gearshift Steering-wheel mounted joystick
Differential ZF type, limited slip, auto-locking differential
Clutch Hydraulically-controlled single disc
Axles and suspension systems
Front McPherson-type strut, two-way adjustable shock absorbers, adjustable camber settings
Front track 1465 mm
Programmed deflection, torsion beam suspension with coil springs and two-way adjustable shock absorbers
Rear track 1430 mm
Brakes
280mm-diameter ventilated discs (front)
240mm-diameter solid discs (rear)
Wheels
Rims One-piece aluminium wheel rims, 6.5x16 (tarmac) and 6x15 (gravel)
Tyres BFGoodrich 195/50 R16 (tarmac) and 175/70 R 15 (gravel)
Kerb
weight ballasted to 1,030 kg (per regulation)
Στην γαλλία βέβαια θα υπάρξει και ενιαίο πρωτάθλημα 6 γυρών στο όποιο η renault θα απονέμει τα εξής έπαθλα στους 6 πρώτους ... πολυ μπροστά
Prizes after each round of the French Twingo R2 Trophy
- 1st: cheque for 1,500 €, voucher worth 1,000 € (ex VAT) from the Renault Sport Racing Spare Parts Department and a set of 4 BFGoodrich tyres.
-2nd: cheque for 1,000€, a voucher worth 500€ (ex VAT) and 2 BFGoodrich tyres
-3rd: cheque for 500€, a voucher worth 500€ (ex VAT) and 2 BFGoodrich tyres
-4th: cheque for 400€, a voucher worth 400€ (ex VAT) and 2 BFGoodrich tyres
-5th: cheque for 200€ and a voucher worth 400€ (ex VAT)
-6th: voucher worth 400€ (ex VAT)
-7th: voucher worth 300€ (ex VAT)
-8th: voucher worth 200€ (ex VAT)
οι επόμενες αφιερωμένες στον proedro
περισσότερες φωτογραφίες εδώ
YΓ μου αρέσει ιδιαιτερα αλλά εγώ θα έπαιρνα fiesta r2 επειδή με ένα πρόχειρο υπολογισμό μου έρχεται φθηνότερο και μου αρέσει το χώμα και εκεί οι "πετεινοί" δεν θυμίζονται ......
Πέμ Απρ 29, 2010 7:13 pm
Δημοσίευση Re: Renault Twingo Sport R2
καλα στο 2ο video πως πεταει ετσι το Twingo? Γ@μ@ει...
Παρ Απρ 30, 2010 8:19 am
Υπεροχο αγωνιστικο,εγω θα το προτιμουσα εναντι του Φιεστα λογω ομορφιας,λογω καλυτερης αισθησης(οπως το βλεπω απ εξω μου δινει την εντυπωση οτι στριβει καλυτερα απο το Φορντακι) και λογω εμπειριας των Γαλλων σε μικρες βομβες-γιγαντες των βουνων!!!
Παρ Απρ 30, 2010 6:04 pm
Περισσότερα εδώ
Πέμ Φεβ 16, 2012 11:50 am
πολυ συμπαθητικο...!
Παρ Φεβ 17, 2012 12:01 am
Δημοσίευση Re: General Rally Videos
Twingo R2 Evo...Δυνατό!
Τρί Σεπ 11, 2012 6:50 pm
Καλά αυτό όλο χοροπηδάει. Όλο στον αέρα είναι. Πόσα κιλά είναι? Πάνω γράφει "Kerb: weight ballasted to 1,030 kg (per regulation)"
Τετ Σεπ 12, 2012 10:08 am
ειδικά στα κλειστά χωμάτινα κομμάτια θα είναι πολύ καλό ..... στα ανοιχτά θα είναι κάπως "δυσκολοδηγητο" ελέω μικρής καρότσας ....... απο τα λίγα renault και ίσως το μαναδικό που θα μπορεί να πάει και στο χώμα ....
Τετ Σεπ 12, 2012 10:22 am
H M-Sport ανακοίνωσε την εξέλιξη του Fiesta S2000!
SUBARU IMPREZA 2.0 SPORT 8/08
Δ. Συζήτηση: Αγγελίες
Συγγραφέας: Nikolas-Ron
Renault Alpine
Fleece M-Sport Ford WRT
