[ +/- ] [ Τώρα είναι Κυρ Οκτ 11, 2026 8:53 am ]
Δημιουργία νέου θέματος Απαντήστε στο θέμα  [ 1044 Δημοσιεύσεις ]  Μετάβαση στην σελίδα Προηγούμενη  1 ... 38, 39, 40, 41, 42, 43, 44 ... 105  Επόμενο
Δημοσιεύματα κάνουν λόγο πως η FIA σκέφτεται την διεξαγωγή της κατατακτήριας ειδικής διαδρομής και στους ασφάλτινους αγώνες μιας και κρίθηκε άκρως επιτυχημένη το 2012 στους χωμάτινους.
Την πληροφορία την έδωσε ο Robert Reid αντιπρόεδρος της επιτροπής της FIA στα θέματα του WRC.
Υγ πολλοί βέβαια τον θυμούνται απο τον αείμνηστο
Τρί Σεπ 25, 2012 1:52 pm
Τα νέα σήμερα είναι πολύ καλά ..... έχουμε και λέμε
Peugeot 208 R5
Ford Fiesta R5
autosport.com έγραψε:
M-Sport confirms it is building a Ford Fiesta R5 car
M-Sport has confirmed it is building a Ford Fiesta R5 car, following AUTOSPORT's exclusive story last week.
M-Sport's commercial director John Steele admitted work on the all-new Fiesta had actually begun, with the first test car expected to be running before the end of the year.
Steele said: "We have had a team working on the project since May this year, following the initial evaluation work that had been undertaken."
He added that the new car - aimed at regional and domestic rallying in the world - would fit neatly into M-Sport's range of R1, R2, Super 2000, Regional Rally Car and World Rally Car Fiestas.
He added: "The intention is that the R5 will complement the already successful Ford Fiesta S2000 and the Ford Fiesta WRC and RRC models that have been very competitive in regional series around the world. The R5 will be based on the 1.6 turbo Fiesta ST road car and use a lot of the design knowledge and experience generated from the S2000 and the World Rally Car. At the same time, it will be a new car with new engine, transmission, roll cage, fuel tank, electronics, all complying with the strict FIA regulations on design and costs.
"We are intending to have the first cars running before the end of the year with the car homologated in the spring of 2013 and available for sale as soon as possible after that.
"The emphasis on the design team has been the take the parts of the S2000 and World Rally Car that we know work very well and try to remove as much complexity as possible. We're looking to retain the dynamics but to simplify the manufacturing processes and try to make it as easy as possible to use and maintain. It is intended that this car will be able to be used in regional series with the minimum amount of technical support from the engineers here."
M-Sport is hoping to emulate the success of its Fiesta S2000, which has sold around the world.
"We are," said Steele, "predicting that the build numbers will be similar to the S2000 and we are working to make the car as economical as possible - the target is to make it half the price of the WRC. But this will only be confirmed once the test programme has been completed."
Hyundai i20 WRC
Τετ Σεπ 26, 2012 9:39 pm
και ελληνικό κειμενάκι στο http://www.highoctane.gr/sbj.aspx?sbj=3221&comp=hyundai
για να δούμε, θα τα καταφέρουν απέναντι στην VW που ιδίως το 14 θα είναι πανίσχυρη;
Πέμ Σεπ 27, 2012 9:28 am
Πέμ Σεπ 27, 2012 10:05 am
Πέμ Σεπ 27, 2012 10:07 am
Tα R5 σε τι θα διαφέρουν απο τα S2000 ?
Θα είναι πιο γρήγορα ή πιο αργά ?
Πέμ Σεπ 27, 2012 10:22 am
Θα είναι κάτι αντίστοιχο με τα σημερινά S2000 1.6T δηλαδή λιγότερα αεροδυναμικά βοηθήματα, μικρότερο στόμιο υπερτροφοδότησης (30mm) κτλ αλλά το σημαντικότερο θα είναι πως θέλουν να φέρουν το κόστος τους στο μισο σε σχέση με ένα WRC δηλαδή γύρω στα 200.000 €.
Εν τέλει τα R5 θα αντικαταστήσουν τα S2000 και σαν ορολογία.
Πέμ Σεπ 27, 2012 10:37 am
Ρεστρίκτορας λέγεται Γρηγόρη. Ρώτα και τον πρόεδρο! 8-)
Πέμ Σεπ 27, 2012 12:14 pm
τα πνευματικά δικαιώματα της ορολογίας "Ρεστρίκτορας" τα έχει ο μεγάλος Νικόλας Περατινός..... :)
Πέμ Σεπ 27, 2012 12:38 pm
Αυτή την στιγμή διεξάγεται συνέντευξη τύπου της Citroen Racing στα πλαίσια του σαλονίου αυτοκινήτου του Παρισίου.
Εκεί ανακοινώθηκε
    Ο νεός χορηγός της Citroen θα είναι η Abu Dhabi
    O Loeb θα κάνει επιλεκτικούς αγώνες το 2013 καθώς αυτός και η Citroen θα ετοιμάζονται για το WTCC του 2014.Κατά την διάρκεια της χρονιάς θα μοιράζεται το bucket ενός DS3 μαζί με το Neuville.
    Πρώτος οδηγός της ομάδας θα είναι ο Mikko Hirvonen.
    To τρίτο Ds3 θα το οδηγεί ο Khaleed Al-Qassimi
Υγ σίγουρα ο Ogier και οι VAGητες θα είναι ράκος ..... :)
Πέμ Σεπ 27, 2012 12:56 pm
Κατηγορία S-WRC το 2010
Απαντήσεις: 662
10 κιλά ροπή μόνο!!!
Συγγραφέας: NIKOS P
