[ +/- ] [ Τώρα είναι Κυρ Νοέμ 29, 2026 1:40 am ]
Δημιουργία νέου θέματος Απαντήστε στο θέμα  [ 39 Δημοσιεύσεις ]  Μετάβαση στην σελίδα Προηγούμενη  1, 2, 3, 4  Επόμενο
 Ford Fiesta WRC 2011
Δημοσίευση Re: Ford Fiesta WRC 2011
καλή αρχή λοιπόν για το Fiestaκι να δούμε τι θα δείξουν τα χρονόμετρα!!!!!!
Τετ Ιαν 19, 2011 3:22 pm
παρουσίαση του Fiesta WRC 2011 απο τα αρχηγεία της Μ Sport στην Αγγλία
Πέμ Φεβ 03, 2011 8:11 pm
Xειρουργείο!!!!!!!!!!!!!!!
Πέμ Φεβ 03, 2011 8:47 pm
FIESTA RS WORLD RALLY CAR TECHNICAL SPECIFICATION
ENGINE
    Ford EcoBoost 1600cc direct injection engine developed by Ford, M-Sport and Pipo Moteurs. Four cylinders, 16 valves. Bore 83.0mm. Stroke 73.9mm. Cosworth electronic engine management system. Garrett turbocharger (with FIA required 33 mm inlet restrictor). Air intercooler. Catalytic converter.
POWER
    300 bhp at 6000 rpm
TORQUE
    450 Nm at 4000 rpm
TRANSMISSION
    Permanent four-wheel drive. Mechanical front and rear differentials and a clutch disconnect fitted to handbrake. M-Sport / X-Trac six-speed sequential gearbox with mechanical shift. M-Sport / AP Racing twin disc clutch.
SUSPENSION
    Front and rear: MacPherson struts with Reiger external reservoir dampers, adjustable in bump and rebound. Fully adjustable fabricated steel links. Front and rear anti-roll bars. Machined aluminium uprights.
BRAKES
    Gravel (front and rear): 300mm Brembo ventilated discs with Brembo four- piston monoblock calipers.
    Asphalt (front and rear): 355mm (maximum) Brembo ventilated discs with Brembo four-piston monoblock calipers.
    Hydraulic handbrake; Adjustable front / rear bias.
STEERING
    Power-assisted high-ratio (12:1) rack and pinion. One and a half turns lock to lock.
WHEELS
    Gravel / Snow: 7in x 15in (aluminium) wheels with Michelin 650mm tyres.
    Asphalt: 8in x 18in (aluminium) wheels with Michelin 650mm tyres.
BODYSHELL
    Unitary construction. Unique composite side panels. Welded T45 steel safety roll cage. Aerodynamic rear wing. Unique front bumper treatment.
ELECTRONICS
    Full Cosworth chassis and engine data acquisition for on-event diagnostics and performance development.
FUEL TANK
    FIA FT3.5 tank, 80 litre capacity, located centrally.
DIMENSIONS
    Length: 3963mm. Width: 1820mm. Wheelbase: 2480mm. Weight: 1200kg minimum.
Πέμ Φεβ 03, 2011 9:14 pm
Δευτ Φεβ 21, 2011 1:20 pm
ελπίζω φέτος να το πάρει το πρωτάθλημα, άντε γιατί πολύ αέρα έχουν πάρει οι γάλλοι.
Δευτ Φεβ 21, 2011 8:07 pm
Παίδες έχετε δίκιο...να κλεινετε τις πόρτες γιατί μπάζει..... :headbang :headbang :headbang :headbang
Δευτ Φεβ 21, 2011 8:47 pm
Απο το 2004 μέχρι το 2010. ο λεμπ πέρνει πρωτάθλημα. Ο λαός λέει: "το πολύ το κυριε ελέησον το βαριέται και ο παπάς". Δεν λέω, είναι 7 ολόκληροι τίτλοι, μαγκιά τους. Ούτε λέω να "πέσει σαν ομάδα". Απλά πρέπει να τους φτάσει η Ford, αν δεν τους έχει φτάσει ήδη με το Fiesta!
Δευτ Φεβ 21, 2011 9:18 pm
Στο 0:21-0:22 ακουγετε κάτι :headbang που δεν περίμενα να το ακούσω απο καινούργιο wrc...μακάρι αν δυναμώσουν και άλλο μέσα στο 2011 ή και τις επόμενες χρονιές να ακούμε αυτο τον ήχο περισσότερο 8-)
Δευτ Φεβ 21, 2011 11:27 pm
Panrok90 η citroen έχει πάρει 6 τίτλους και ο κοντός 7. το πρωτάθλημα σίγουρα θα είναι πιο απρόβλεπτο και πιο συναρπαστικό απο τα προηγούμενα χρόνια λόγω των νέων αυτοκινήτων τόσο από άποψη νεότητας και έτσι πιθανών προβλημάτων που μπορεί να έχουν όσο και απο τον διαφορετικό τρόπο στην οδήγηση τους ( πιο "νευρικό" ελέω έλλειψης κεντρικού διαφορικού)σε σχέση με την προηγούμενη γενιά των wrc.
Saxter 1-2-3 .....
Δευτ Φεβ 21, 2011 11:40 pm
Rallye Du Var (France 2011)
4ος Αγώνας GTCC'11 - Πάτρα 25 Σεπτεμβρίου 2011
