[ +/- ] [ Τώρα είναι Παρ Οκτ 09, 2026 7:01 pm ]
 IRC - Islas Canarias Rally
Δημοσίευση IRC - Islas Canarias Rally
EVENT ESSENTIALS
    Event: Rally Islas Canarias El Corte Inglés, Intercontinental Rally Challenge, round two of 13
    Starts: Las Palmas, 07:00hrs, Friday 16 March
    Finishes: Las Palmas, 18:15hrs, Saturday 17 March
    Base and permanent service park: Las Palmas, Gran Canaria
    Surface: Asphalt
    Entries received: 31
    IRC appearances: Two (2010 and 2011)
    Stages: 15
    Stage distance: 240.92 kilometres
    Liaison: 519.47 kilometres
    Total: 760.39 kilometres
H διαφορά ώρας των Κανάριων Νήσων με την Ελλάδα είναι -2 ώρες υπερ της Ελλάδος.
Παρ Μαρ 16, 2012 1:11 pm
Δημοσίευση Re: IRC - Islas Canarias Rally
Live Timing
Παρ Μαρ 16, 2012 1:21 pm
5η και 11η φωτο...
Αυτα ειναι Polo WRC???
Η απο καποια αλλη ομαδα-δορυφορο????
Παρ Μαρ 16, 2012 8:10 pm
Panos Volos έγραψε:
5η και 11η φωτο...
όχι .... προφανώς πρόκειται κάποια replica .....
Παρ Μαρ 16, 2012 8:19 pm
After SS10: Mikkelsen fastest, Gassner Jr crashes
Andreas Mikkelsen has shot back into the lead of Rally Islas Canarias El Corte Inglés by winning Saturday’s first test, the 13.28-kilometre Maspalomas stage.
The reigning Intercontinental Rally Challenge champion was 3.1s quicker than overnight leader Jan Kopecký, also in a ŠKODA Fabia Super 2000, to move 1.9s ahead in the overall classification.
“It was a good push, on the limit sometimes, it’s a good fight,” said Mikkelsen.
Kopecký said: “I have to say it was quite quick. In the recce I said it would be a fast stage but it was actually more quick than I thought.”
While Luis Monzón completed the stage without issue with the third fastest time in his Peugeot 207 S2000, Hermann Gassner Jr was less fortunate, crashing his Red Bull Team Fabia and inflicting substantial damage to the left-rear corner.
Fellow German Sepp Wiegand, who was running behind Gassner Jr on the road, said: “I think he went off, there was left-rear damage and he’s out. I’m really sorry because it was a nice fight and we are fighting together. He’s okay, he stands out of the car.”
Maspalomas is an all-new stage for 2012 and is described as been fast and flowing with a big drop in one section.
Go to the Live Results section for more information http://irc-results.com/2012/rally-islas-canarias-2012/
Μάχη για την πρώτη θέση μεταξύ Skoda Uk και Skoda Motorsport.....
Σάβ Μαρ 17, 2012 2:08 pm
Γιατί κάτι μου λέει ότι του χρόνου δεν θα υπάρχουν οι Κανάριες νήσοι στο καλεντάρι ??
Σάβ Μαρ 17, 2012 10:37 pm
Νίκη για Jan Kopecky αφού ο Mikkelsen αντιμετώπισε πρόβλημα με τον κινητήρα του.
Το πρώτο Peugeot βρίσκεται στην 3η θέση με τον Ισπανό Luis Monzón.
Εντύπωση κάνει το Swift S1600 στην 6η θέση με τον επίσης Ισπανό Joan Vinyes.
Σάβ Μαρ 17, 2012 11:17 pm
4tforum.gr έγραψε:
IRC: Δραματική νίκη Kopecky!
Ο δεύτερος γύρος του Intercontinental Rally Challenge εξελίχθηκε σε παράσταση αποκλειστικά για δύο. Πριν την έναρξη του αγώνα, έμοιαζε δεδομένο ότι οι Andreas Mikkelsen και Jan Kopecky θα αποτελέσουν τους διεκδικητές της νίκης, με τον καθένα να θέλει τη νίκη για τους δικούς του λόγους. Ο Νορβηγός οδηγός της επίσημης αντιπροσωπείας της Skoda στη Μ. Βρετανία προερχόταν από ένα σερί νικών που έχει ξεκινήσει από πέρσι και συνεχιζόταν μετά την επικράτηση του στον εναρκτήριο αγώνα του θεσμού στις Αζόρες. Ο Mikkelsen δεν έχει καταφέρει ακόμα να κερδίσει σε ασφάλτινο αγώνα και ήθελε να δώσει στους Κανάριους Νήσους ένα τέλος σε αυτή την κακή παράδοση. Ο Kopecky από την πλευρά του, είχε την παράδοση με το μέρος του, αφού η ταχύτητα του στην άσφαλτο είναι αδιαπραγμάτευτη, ενώ ήθελε να συνδυάσει την παρθενική του εμφάνιση για το 2012 με νίκη.
Έτσι, λοιπόν, οι δυο τους ξεχώρισαν από την πρώτη ειδική του αγώνα, επαληθεύοντας τις προβλέψεις για μία μάχη με δύο πρωταγωνιστές. Για δύο ημέρες, ο Mikkelsen και ο Kopecky αντάλλασαν δευτερόλεπτα, με την διαφορά τους στην τελευταία ειδική του αγώνα να είναι μόλις 3,6 δευτερόλεπτα υπέρ του πρώτου! Και ενώ όλα έδειχναν ότι ο Νορβηγός θα κατάφερνε να σημειώσει την πρώτη του νίκη σε ασφάλτινες επιφάνειες, ένα πρόβλημα στον κινητήρα του Skoda Fabia S2000 με αποτέλεσμα την απώλεια ισχύος, του κόστισε περίπου μισό λεπτό και μαζί τη νίκη, περιορίζοντας τον στην δεύτερη θέση της γενικής. Στο τέλος ο Mikkelsen ήταν απαρηγόρητος, αφού βλέπει ότι η τύχη δεν είναι με το μέρος του στην άσφαλτο. Βλέπετε, πέρσι στην Ουγγαρία βγήκε από το δρόμο ενώ προηγούταν με σημαντική διαφορά. Αντίστοιχα, στο Σαν Ρέμπο έχασε τη νίκη μέσα από τα χέρια του στην τελευταία ειδική από τον νυν οδηγό της Citroen, Thierry Neuville, ενώ τώρα την επικράτηση του αρνήθηκε ο κινητήρας του Skoda.
Με αυτόν τον τρόπο, ο Jan Kopecky στην πρώτη του για το 2012, κατάφερε να σημειώσει τη δεύτερη του νίκη στα Κανάρια νησιά, μετά από αυτή που είχες σημειώσει το 2010. Πάντως, προς τιμήν του, ο Τσέχος δεν πανηγύρισε τη νίκη του στο τέλος, δηλώνοντας χαρακτηριστικά: «Στις τρεις τελευταίες ειδικές πιέσαμε στο όριο και καταφέραμε να μειώσουμε τη διαφορά μας από τον Andreas. Ό,ως, δεν μπορώ να πω ότι απολαμβάνω ιδιαίτερα αυτή τη νίκη, αφού ήθελα να τον κερδίσω μετά από μάχη. Όμως, αυτά συμβαίνουν στους αγώνες Ράλλυ και από την μεριά μου θα ήθελα να ευχαριστήσω την Skoda που μου παρείχε ένα εξαιρετικό και αξιόπιστο αυτοκίνητο». Το βάθρο, συμπλήρωσε ο νικητής του αγώνα το 1991 και το 1994 Luis Monzon, ο οποίος και οδηγούσε ένα Peugeot 207 S2000. Σημειώστε, ότι ο ίδιος είναι υπεύθυνος και για το promotion του αγώνα. Πίσω του, ακολούθησε ο νεαρός Γερμανός Sepp Wiegand με το Skoda Fabia S2000 της γερμανικής αντιπροσωπείας, ενώ στο βάθρο θα μπορούσε να είχε τερματίσει ο συμπατριώτης του Hermann Gassner Jr., αν δεν είχε έξοδο με το Skoda Fabia S2000 στα χρώματα της Red Bull.
Τελικά Αποτελέσματα
1. Jan Kopecky Skoda Fabia S2000 2:21:46.5
2. Andreas Mikkelsen Skoda Fabia 2000 + 28.3
3. Luis Monzon Peugeot 207 S2000 + 3:13.6
4. Sepp Wiegand Skoda Fabia S2000 + 4:32.0
5. Jonathan Perez Peugeot S2000 + 7:29.3
6. Joan Vinyes Suzuki Swift S16000 + 9:00.3
7. Gorka Antxustegi Suzuki Swift S16000 + 9:18.9
8. Angel Marrero Honda Civic Type-R + 11:27.4
9. Janos Puskadi Skoda Fabia S2000 + 12:03.3
10. Rashid Al Ketbi Skoda Fabia S2000 + 14:43.2
Δευτ Μαρ 19, 2012 5:53 pm
Δευτ Μαρ 19, 2012 8:19 pm
Τετ Απρ 04, 2012 4:47 pm
Απαντήσεις: 40
WRC RALLY MONTE CARLO 2016
Απαντήσεις: 87
WRC Wales Rally GB 2016
Απαντήσεις: 45
Ford Rally Legends
